Maryan
Oct 11, 2020Aspirant
NETGEAR Nighthawk AX12 and UK ISP Setup
Hello everyone! I have a question regarding proper connection for AX12 router in the UK. As we know in the UK we have VDSL & ADSL connection, so we need to use modem in order to be able to connect ...
- Oct 19, 2020
Sounds good, try both and I might keep them both just in case one went down.
Maryan
I forgot to mention I need a good router for gaming too so hope this AX12 will be a good choice or if not please let me know your recommendation from Netgear Nighthawk router range.
Thanks so much!
- Christian_ROct 15, 2020NETGEAR Employee Retired
Hello Maryan,
Welcome to the community! Did you end up getting the AX12 router?
Christian
- MaryanOct 15, 2020Aspirant
Hi,
Thank you for your answer.
No, I didn't decied yet. In 26 October I'm moving my broadband to BT, so they going to send me a brand new BT Smart Hub which I can use as a modem.
Then I can connect it to AX12, but I'm not too sure if this is a good setup example.
Maybe I will need an other good modem (just modem) before AX12 instead of BT Smart Hub Router.
This is why I asked the question here as Netgear community knows best what should be the best one.
All I need is to have a rock solid connection and good network range.
I was also thinking about adding a mesh extender like EX7700.
Many thanks
- NewfiedroolOct 15, 2020Virtuoso
BT home hubs for domestic use don't do modem only mode, you would need a modem to suit your line unless it's a business homehub which does allow modem only and that's for BT business customers.
I use a HG612 then the router attaches to that and away I go.
ive the RAX120 and use the EX8000 extender and it works well. NG have 2 AX extenders which if you wanted to remain in AX land are needed. Check out the EAX20 and EAX80.
