Maryan
Oct 11, 2020Aspirant
NETGEAR Nighthawk AX12 and UK ISP Setup
Hello everyone! I have a question regarding proper connection for AX12 router in the UK. As we know in the UK we have VDSL & ADSL connection, so we need to use modem in order to be able to connect ...
- Oct 20, 2020
Sounds good, try both and I might keep them both just in case one went down.
Newfiedrool
Oct 16, 2020Virtuoso
BT home hubs for domestic use don't do modem only mode, you would need a modem to suit your line unless it's a business homehub which does allow modem only and that's for BT business customers.
I use a HG612 then the router attaches to that and away I go.
ive the RAX120 and use the EX8000 extender and it works well. NG have 2 AX extenders which if you wanted to remain in AX land are needed. Check out the EAX20 and EAX80.
Maryan
Oct 16, 2020Aspirant
Thanks for your answer.
I had HG612 previously but I throw it to the bin many years ago, having DrayTek Vigor 2850N this modem was useless.
HG612 is a very old modem, not longer manufactured and supported by Openreach.
I'm looking for a decent solution right now.
Regarding BT Smart Hub I can always switch WIFI off and I have a modem, but still I don't think this is a professional solution.
- NewfiedroolOct 17, 2020Virtuoso
You will end up with NAT issues if you just turn the WiFi off on the home hub, ie double NAT.
While the HG612 is no longer issued by BT it's still well used and you can find unlocked ones on EBay or unlock one your self.
I great performance with mine and no issues as it's just a modem .You should be able to find one for about £20.
