Maryan
Oct 11, 2020Aspirant
NETGEAR Nighthawk AX12 and UK ISP Setup
Hello everyone! I have a question regarding proper connection for AX12 router in the UK. As we know in the UK we have VDSL & ADSL connection, so we need to use modem in order to be able to connect ...
- Oct 19, 2020
Sounds good, try both and I might keep them both just in case one went down.
psychopomp123
Oct 19, 2020Luminary
OP, just get a Draytek 130 VDSL modem and hook that up to the router of your choice, eg Netgear AX12. I'm also in UK and using the AX12 on my BT FTTP line and its the best router I've ever used for wifi range & coverage. Buy it, you won't regret it!
Maryan
Oct 19, 2020Aspirant
Thanks guys, yes the AX12 seams to be one of the best when come to the WiFi range and features I need for gaming.
Thanks for all the advices! Seams that HG612 and Draytek 130 are only raliable modem solution for this time in UK.
I have read a lot recently regarding Draytek 130 and users who was testing it against HG612 and the results was pretty the same.
HG612 had a slightly better performance, but I think I will get them both and test them for myself. The winner will stay with me for good, the looser will go back on eBay :)
- NewfiedroolOct 19, 2020Virtuoso
