Xiong
Aug 12, 2020Aspirant
Netgear Nighthawk AX12
The router frequently disconnects, prompting no IP address, unable to connect to the IP for a long time
Aug 14, 2020Guru - Experienced User
Xiong wrote:Ax12 is the latest firmware.---no its not. AX12 isn't a firmware number. I can’t connect to the network but the Wifi is connected normally----This makes zero sense. you can't connect but you can connect?. If there is no network, the router needs to be restarted for normal operation. The same problem exists when I restore the factory settings.
And the other info? LIke modem/gateway?
Please make sure to be details and precise. We aren't there to see what you're doing/done.
Xiong
Aug 14, 2020Aspirant
v1.0.1.122 is the latest firmware
