Xiong
Aug 13, 2020Aspirant
Netgear Nighthawk AX12
The router frequently disconnects, prompting no IP address, unable to connect to the IP for a long time
CJRATLIFF
Nov 30, 2020Aspirant
I just installed this router and had my laptop WIFI disconnect twice in 4 hours. If this router is junk I need to return ASAP. I changed my NTP setting, changed DNS to Google and disabled broadcast of SSID for guest. I will see what happens.
Router Firmware Version V1.0.2.136
Should I just return??? Is this product junk?
