ruli0001
Nov 16, 2022Tutor
NETGEAR Nighthawk AX2400 AX6 5-Stream WiFi 6 RAX30
I have an issue with the router. The internet LED is off and the only way to get the internet back is to restart the router. It happens almost every week. After turn it off and on then the interne...
ruli0001
Nov 17, 2022Tutor
It has the latest firmware 1.0.7.78
See attached the ONT picture
We use cat 5e and it should be ok. We just bought it like 5 months. As soon as I restart it then it works again.
Nov 17, 2022Guru - Experienced User
Do you happen to know if there a is built in router at the ONT or just a ONT only? I presume it's just an ONT.
I would recommend CAT6 for sure though.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What devices do you all have connected to the router?
Any other devices near by the router?
- ruli0001Nov 17, 2022Tutor
Just ONT
Any Wifi Neighbors near by? If so, how many?We don't use the WIFI, we use the router for cable connection only
Just printer, Orbi and some desktops
Any other devices near by the router? Orbi
- FURRYe38Nov 17, 2022Guru - Experienced User
So you have a Orbi system next to the RAX?
What model is this Orbi sytem?Is the wifi radios on the RAX disabled?
How close is the Orbi system next to the RAX router?
Yes, just for wifi.
What model is this Orbi sytem?RBK50 (2017)
yes
