Texas1958
May 05, 2023Follower
Netgear Nighthawk AX2400 RAZ30-100NAS
I know very little about what I'm about to ask. Is there a way to turn off the 5G and just use the 2.4G ?
microchip8
May 05, 2023Master
Go with a browser to http://routerlogin.net or http://192.168.1.1 and turn off whatever you want.
If your model has a physical button for 5 GHz, you can use that.
michaelkenward
May 06, 2023Guru - Experienced User
If Texas1958 owns the RAX30, and not a RAZ30 (which doesn't seem to exist), then there is indeed a button/LED on the top to turn off the 5 GHz wifi.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in the model number and check the documentation for the hardware.
Look for the model number on the label on the device.
Check the section in the manual Top panel LEDs and buttons
