Texas1958
May 05, 2023Follower
Netgear Nighthawk AX2400 RAZ30-100NAS
I know very little about what I'm about to ask. Is there a way to turn off the 5G and just use the 2.4G ?
May 06, 2023Guru - Experienced User
My questions is more directed at why you want to turn it off?
5ghz doesn't interfere with 2.4ghz and is significantly faster. Why are you wanting it disabled?
- michaelkenwardMay 06, 2023Guru - Experienced User
That did occur to me.
I wondered if it was someone trying to setup an IoT device.
If you are plagued by a badly written mobile app that can't work with a Mesh syustem that uses the same SSID for 2.4 and 5 GHz temporarily turning off 5 GHz can be useful.
Otherwise it is probably a bad idea.
