Texas1958
May 05, 2023Follower
Netgear Nighthawk AX2400 RAZ30-100NAS
I know very little about what I'm about to ask. Is there a way to turn off the 5G and just use the 2.4G ?
May 06, 2023Guru - Experienced User
My questions is more directed at why you want to turn it off?
5ghz doesn't interfere with 2.4ghz and is significantly faster. Why are you wanting it disabled?
michaelkenward
That did occur to me.
I wondered if it was someone trying to setup an IoT device.
If you are plagued by a badly written mobile app that can't work with a Mesh syustem that uses the same SSID for 2.4 and 5 GHz temporarily turning off 5 GHz can be useful.
Otherwise it is probably a bad idea.
