seetaramrao
Sep 16, 2020Initiate
Netgear nighthawk AX3000 Wifi RAX35 dropping wifi connection frequently
Everyday my wifi network disappears. I see 3 green lights on wifi router. Please help me
- Eagle-TwoApprentice
Are you using firmware version 1.0.3.80? I'm having simliar issues with my RAX35 but it happens less often after I disabled AX.
- seetaramraoInitiate
Yes, I downgraded to previous version.
Could you please provide me steps to disable AX?
In 1.0.3.80 firmware version its under Basic / Wireless / Enable AX. I'm not sure about other firmware versions.
- beat__riceAspirant
Same issue and same model. Happens at least once daily for the past week now. Only fix I have found is manually power cycling. Will try disabeling AX and see how that works.
