jkb24212
Jul 08, 2020Aspirant
Netgear nighthawk AX3000
I am unable to reach the router’s setup place using the default ip of 192.168.1.1 since the iOS app did not allow me to change the SSID and the wireless password. I did a reset then could not find the...
- Jul 09, 2020Thanks, did not try the CMD & ipconfig because I was finally able to connect this AM wirelessly after all attempts for hardwire failed.
Jul 09, 2020Guru - Experienced User
have you tried hardwiring into it to access it?
If you connect to the router you can open a command prompt and type ipconfig the default gateway should be the ip address for the router
- jkb24212Jul 09, 2020AspirantThanks, did not try the CMD & ipconfig because I was finally able to connect this AM wirelessly after all attempts for hardwire failed.
