jkb24212's avatar
jkb24212
Netgear nighthawk AX3000
I am unable to reach the router’s setup place using the default ip of 192.168.1.1 since the iOS app did not allow me to change the SSID and the wireless password. I did a reset then could not find the...
  • jkb24212's avatar
    jkb24212
    Jul 09, 2020
    Thanks, did not try the CMD & ipconfig because I was finally able to connect this AM wirelessly after all attempts for hardwire failed.
