Ganz_Anders
Feb 14, 2022Initiate
netgear nighthawk ax4
Hello, is it possible to make a mesh configuration with 2 netgear nighthawk ax4 devices ? thus Router to Router ?
- Feb 14, 2022
Mesh? No.
Can you use one in router mode and the other in access point mode? Sure.
You can even name them the same. Devices can roam based on their own roaming protocol. They'll be a little "stickier" than a true mesh system like orbi MK nighthawk but you can do it.
Feb 14, 2022Guru - Experienced User
Mesh? No.
Ganz_Anders
Tank you for the fast response
