darry04
Jun 02, 2023Follower
Netgear Nighthawk AX5400 please help!!
Hey guys!! I’m in need of some help!! I am trying to but GliNet Brume 2 before my router (netgear nighthawk ax5400) as a gateway and have vpn/adguard setup! Since I need to disable DHCP on my netgea...
Jun 02, 2023Guru - Experienced User
In AP mode, dhcp is disabled. Its the primary router that manages it.
If you're going glinet--->netgear
then AP mode is the ideal option to leave the glinet managing everything.
michaelkenward
