darry04
Jun 02, 2023Follower
Netgear Nighthawk AX5400 please help!!
Hey guys!! I’m in need of some help!! I am trying to but GliNet Brume 2 before my router (netgear nighthawk ax5400) as a gateway and have vpn/adguard setup! Since I need to disable DHCP on my netgea...
Jun 02, 2023Guru - Experienced User
In AP mode, dhcp is disabled. Its the primary router that manages it.
If you're going glinet--->netgear
then AP mode is the ideal option to leave the glinet managing everything.
KRAZIE9
Jun 02, 2023Aspirant
in the glinet when it set to "drop in gateway" for vpn, adgaurd to work, it still says dhcp is enabled even when router is in AP mode
- plemansJun 03, 2023Guru - Experienced User
You might want to check with glinet.
Again, when the netgear is in access point mode, the glinet is managing everything. It might be how you have your vpn/ad guard setup
