Rubikscube
Feb 01, 2022Aspirant
Netgear Nighthawk AX6 AX 4300 ADVANCED Settings.
Good afternoon, I am seeking assistance from you knowledgeable guys. Ok here goes, When i log into my routers settings utilizing the 192.168. and i get into the main section, On the upper left ...
Rubikscube
Hi. I am using a Mac And Safari.. Last week I had no issues whatsoever but, this week is a different story. It won't even allow me to click on it as an option.
Feb 01, 2022Guru - Experienced User
Try FF or Opera.
What OSX version are you using? Others have reporting seeing problems with same thing on OSX 11 and 12 and Safari...
- RubikscubeFeb 01, 2022Aspirant
Hi, I already tried those options with no luck.
- plemansFeb 01, 2022Guru - Experienced User
Does it happen on a windows device or android device (through the browser)?
I am using a MacBook.
