di-nana
Sep 16, 2022Follower
Netgear Nighthawk AX6 AX5400
I just purchased this Nighthawk router thinking I was buying a combo modem router to replace my Netgear AC 1900 WiFi Cable Modem Router that is not working up to par. My internet provider seems to t...
microchip8
Sep 16, 2022Master
A router needs a modem. I recommend you seperate the two. A stand-alone modem and router. If one fails, you can easily replace it.
- KitsapSep 16, 2022Master
Short term, you could configure your existing cable modem router for bridge mode operation and that would disable the router portion and leave the cable modem functional. Then connect your new router downstream.
