SS1374
Jun 20, 2020Aspirant
NetGear Nighthawk. AX8, AX6000, 8-Stream wifi router, RAX80 requires daily restart
Greetings from MI I am in need of advice; I am having almost daily issues with no internet available. It requires a restart every day, or other day. Very frustrating. The unit is 85 days "old", ...
Retired_Member
Jul 12, 2020Your issues with the router are similar to with my XR700. Your issues with Netgear Support are similar as well. Check this out:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR700-DHCP-and-WiFi-disconnecting/m-p/1943802#M20261
I think everyone with this issue should describe Netgear's lack of support here:
https://edelson.com/contact/
SS1374
Jul 12, 2020Aspirant
Thank You for the link and for taking time to post!
I am climibing a steep learning curve, and will report my progress!
S
