weifensi
Jul 04, 2020Aspirant
Netgear Nighthawk AX8 (RAX80) and Nighthawk Mesh System
I'm thinking to buy the Netgear Nighthawk AX8 (RAX80) gaming router. I also would like to extend my wifi network with a mesh system and buying the Nighthawk Mesh Wifi system. Given that I'm getting t...
weifensi
Jul 06, 2020Aspirant
Hi there
thanks for the reply.
You are right, the Netgear Nighthawk AX8 (RAX80) is not a gaming router - my bad.
What's the differnence between Orbi mesh (www.netgear.com/orbi/rbk752.aspx) and Nighthawk Mesh (www.netgear.com/home/products/networking/nighthawk-mesh/ ? And would both of them work with the router I mentioned above ?
I have an old Wifi router which needs replacement. Hence, I'm thinking to upgrade to a Wifi 6 router and a mesh system to be fully updated on the latest technology for a while.
thanks again
