jdlawyer
May 08, 2020Aspirant
Netgear Nighthawk Cable Modem WiFi Router Combo (C7800)
I just purchaed the Netgear Nighthawk Cable Modem WiFi Router Combo (C7800). After disconnecting the Xfinity box I was able to connect the Nighthawk and have it go online for internet. My house i...
May 08, 2020Guru - Experienced User
John,
without knowing what your isp has setup for your tv's its tough to give you an answer.
It might be good to check with you ISP as to what you'd need to get your services working with the tv's if you have tv service through them.
- jdlawyerMay 08, 2020Aspirant
thanks
