Kitten00
Dec 14, 2021Follower
Netgear Nighthawk Rax120 Wifi 6 router connection issues. Wifi keeps disconnecting!
I just bought this new wifi 6 router a few weeks ago and now my wifi keeps disconnecting or rebooting..... How many of you are still having the same issue? How is this going to be solved? Return and ...
Dec 14, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
