Kitten00
Dec 14, 2021Follower
Netgear Nighthawk Rax120 Wifi 6 router connection issues. Wifi keeps disconnecting!
I just bought this new wifi 6 router a few weeks ago and now my wifi keeps disconnecting or rebooting..... How many of you are still having the same issue? How is this going to be solved? Return and ...
michaelkenward
Dec 15, 2021Guru - Experienced User
Kitten00 wrote:
I just bought this new wifi 6 router a few weeks ago and now my wifi keeps disconnecting or rebooting..... How many of you are still having the same issue? How is this going to be solved? Return and replace? Need a better router with stable wifi connection.. Any suggentions?
plemans has asked the key questions. What sits in front of this router.
I set in only to ask what you mean by "my wifi keeps disconnecting or rebooting"?
Which is it?
Take us through what goes on and what you see.
Does this happen on every wifi client? What do the LEDs on the router look like when this happens.
But first answer plemans questions.
