Mujahid_G
Sep 22, 2020Aspirant
Netgear Nighthawk RAX120 WIFI 6 router power adapter voltage for different countries
Hi there. I bought a RAX120 WiFi router and I'm a pretty happy with it. I might move in a while to Americas and I know that power sockets there are 110V instead of 220V in my country. So my 220V powe...
Sep 22, 2020Guru - Experienced User
You can just replace it with a 110v power supply. You can't buy them direct but you can get 3rd party one's off amazon/ebay.
Just make sure the output voltage is the same and you have at least the same amperage.
the one you have might work too. I know for a while, netgear was using power supplies that worked for both 110 and 220v but wasn't getting them certified in each country for both. so it would only show the same voltage as that country used. saved a little $ for them.
If you you were feeling adventurous and have a multimeter (and you don't plan on using the power supply again in case it fries) plug it in on the end of an extension cord outside and test it to see if it works.
- Mujahid_GSep 22, 2020Aspirant
plemans wrote:You can just replace it with a 110v power supply. You can't buy them direct but you can get 3rd party one's off amazon/ebay.
Thanks for the reply. I think I'm not that lucky, cause my adapter has 220-240V input written on it. So from your suggestion I understand that I should buy a 3rd party adapter which is 110-220V, which will have 19V and 3.16A output as stated for my adapter's output. And this will work? That's good news then. I won't have to buy a brand new WIFI router when I move!
- plemansSep 22, 2020Guru - Experienced User
correct. but you don't have to buy a 110-220v adapter. Just a 110v would work.
just so long as the output voltage is exactly the same and the amperage is at least as much. You can have higher amps but not lower.
