bkleinschmidt
Mar 11, 2021Follower
NetGear Nighthawk RAX15 - OpenVPN Weak Cipher Suites
Hello,
I have setup OpenVPN on my NetGear RAX15 router and the OpenVPN profiles are pre-configured. Is there way to adjust the ciper suites used as the profiles generated by my router are using outdated weak ciper suites (AES-128-CBC). Also the certificates generated are using RSA 1024 bit public keys with a sha256 hash. It would be nice to be able to repalce the certicates with stroger RSA 4096 bit, and use ciper suites AES-256-GCM. I am uncormatable using outdated encyption and security for my home router. Please let me know if there is a way to configured higher security profiles and/or submit a feature request to do so.
Thank you.
Brian
1 Reply
- Christian_RNETGEAR Employee Retired
Hi Brian,
I'll forward this inquiry to our product teams and get back to you as soon as I can.
Regards,Christian
