apkbyte
Aug 06, 2023Aspirant
Netgear nighthawk rax200 faster then my unifi u6 pro Ap?!
I've been using Netgear for some time and find it runs perfect 90% of the time however some spots in the house speeds were dropping a bit. So decided to purchase a ubiquiti u6 pro and place it in t...
apkbyte
Aug 07, 2023Aspirant
Hi michaelkenward,
Thanks for your reply,
Channel on UNIFI was set to auto: just changed to channel 48 from my wifi scanner app. And speeds seem to be running at full speed now. it recommended channel 48 is the best.
Kitsap
Aug 07, 2023Master
I believe some background reading would enhance your understanding of local area networks and Wi-Fi in general. Pay particular attention to the section covering 160 Mhz wide W-Fi channels. Recommend you bookmark the link as the document is updated on a regular basis.
https://www.duckware.com/tech/wifi-in-the-us.html
Ubiquiti makes good products, they are solid performers but they are not race cars. I have a POE switch for IP cameras and an AC-Pro access point. They can be tricky to get setup and Ubiquiti is forever messing with the firmware. Make sure you do not have firmware auto-update enabled.
