mshort8043
Aug 05, 2024Aspirant
Netgear Nighthawk RAX38 Keeps Disconnecting for our 2 laptops
Netgear Nighthawk RAX38 Keeps Disconnecting for our 2 laptops but everything else works. Will connect for a few minutes then disconnects, then reconnects after a few minutes and repeats. One is a sur...
Aug 05, 2024Guru - Experienced User
try turning smart connect off and seeing if its the 2.4ghz or the 5ghz having issues or both
