mshort8043
Aug 05, 2024Aspirant
Netgear Nighthawk RAX38 Keeps Disconnecting for our 2 laptops
Netgear Nighthawk RAX38 Keeps Disconnecting for our 2 laptops but everything else works. Will connect for a few minutes then disconnects, then reconnects after a few minutes and repeats. One is a sur...
Aug 05, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
Something to check with these two laptop Mfrs about since they seem to be the only ones having problems.
Might check with the Mfr about disabling any MAC address randomizers on these two devices.
Might check into FW updating as well as yours seems to be behind:
mshort8043
Aug 13, 2024Aspirant
Neither worked đ
- FURRYe38Aug 13, 2024Guru - Experienced User
Try disabling AX mode on the router.
If these are the only laptops having problems, I'd get with the Mfr of these laptops for help and information as well.
Ask the Mfr about updating the WiFi adapter chip set drivers on these laptops as well.
