mshort8043
Aug 05, 2024Aspirant
Netgear Nighthawk RAX38 Keeps Disconnecting for our 2 laptops
Netgear Nighthawk RAX38 Keeps Disconnecting for our 2 laptops but everything else works. Will connect for a few minutes then disconnects, then reconnects after a few minutes and repeats. One is a sur...
mshort8043
Aug 13, 2024Aspirant
Neither worked đ
Aug 13, 2024Guru - Experienced User
Try disabling AX mode on the router.
If these are the only laptops having problems, I'd get with the Mfr of these laptops for help and information as well.
Ask the Mfr about updating the WiFi adapter chip set drivers on these laptops as well.
