Ragu49
Feb 18, 2021Aspirant
Netgear Nighthawk RAX40 & Bell Fibe
Ok How do I use the RAX40 with Bell Fibe I just have Fibe line with an ONT coming into house not ethernet or cable..
Ragu49
Actually was looking to not use bell modem period any ideas ho to eliminate it..
jweaver4475
I think with Bell you have to use there modem, I think they call it a "Connection Hub".
It should be included with your service.
Do you have an active service with Bell?
- Ragu49Feb 18, 2021Aspirant
yes and guys are using own routers without the HH3000
- jweaver4475Feb 18, 2021Aspirant
I think you would be better off operaitng the HH3000 in bridge mode.
This basically makes it pass the WAN IP directly to your connected router of choice and disables all the routing features on the HH3000.
There is no bridge mode for HH3000 only option is the DMZ option and I would have to turn off HH wifi for sure but not sure if I can turn off DHCP?
