matthiastrek
Sep 18, 2021Aspirant
Netgear Nighthawk RAX40 cannot connect to more than one device
I have a netgear nighthawk RAX40 which allows me to connect to more than one device wirelessly, but for some reason, only one device can connect to it at a time. I have to switch between my phone and...
Sep 18, 2021Guru - Experienced User
You put you have the RAX40.
1. what firmware is on it?
2. what modem/gateway is it connected to?
3. is it only wired device? wireless devices?
- matthiastrekSep 18, 2021Aspirant
I don't know what firmware it is on. I assume the app would tell you that. I try to use the app to connect to the router, but it can't.
Also not sure about the modem/gateway. I don't use a modem, the router is connected to my apartment building's setup.
No wired devices, it's all wireless devices trying to connect via wifi (laptop, phone, etc)
- plemansSep 18, 2021Guru - Experienced User
Makes it a challenge with apartment supplied setups as you don't know what they have setup controlling it. Or even how they have it configured.
have you contacted your apartment complex's IT person?they might need to allow your router onto the network.
