Retired_Member
Mar 27, 2024Netgear nighthawk rax41 ax3600 router
Starlink is my internet provider.i put starlink in bypass mode setup the nighthawk router and I have a wired connection to my xbox series x console.I went into nighthawk router setting did auto config...
Mar 27, 2024Guru - Experienced User
If you have the ISP modem in bypass or DMZ there for the RAX router, and xbox is getting OPEN NAT, then this is the best you can get. You should be able to get OPEN NAT with or with out IPv6.
Recommend using a ethernet connection to xbox for best performances in gaming.
Try connecting the xbox to the ISP router to compare results.
