Anonymous
Mar 27, 2024Netgear nighthawk rax41 ax3600 router
Starlink is my internet provider.i put starlink in bypass mode setup the nighthawk router and I have a wired connection to my xbox series x console.I went into nighthawk router setting did auto config...
Mar 27, 2024Guru - Experienced User
If you have the ISP modem in bypass or DMZ there for the RAX router, and xbox is getting OPEN NAT, then this is the best you can get. You should be able to get OPEN NAT with or with out IPv6.
Recommend using a ethernet connection to xbox for best performances in gaming.
Try connecting the xbox to the ISP router to compare results.
Anonymous
Mar 27, 2024Now xbox says ipv4 and ipv6 open nat and I haven't been kicked outta race on forza like I was before replacing starlink router.I just want to make sure all was good on my end because I have never had to deal with any of this before.Should I disable the ipv6 auto setting or leave it be.
- FURRYe38Mar 27, 2024Guru - Experienced User
Leave it be.
Something to ask the ISP about to see if you can remove there router and put the RAX in place of it. They will have this information.
- plemansMar 27, 2024Guru - Experienced User
I would test it both ways. The starlink routers are supposed to be pretty solid.
I'd test it 3 ways.
1. star link router in passthrough to netgear router. Xbox connected to netgear
2. Starlink router in router mode with netgear in access point mode. xbox connected to netgear
3. starlink in router mode. xbox direct connected to it.
You will see some additional latency going starlink---netgear----xbox just because you added another step on the process but it'd be worth seeing what each setting change adds to the process.
- AnonymousApr 07, 2024I bought this router and was wanting to know best way to set it up for gaming on ps5 and xbox series x cause I have been having lag and just want to know best settings and how to do it.TIA
