Corna
Nov 30, 2020Initiate
NetGear Nighthawk RAX50 - slow wifi speed , and limited speed on PC
Hi I have a NetGear Nighthawk RAX50 ( brand new AX ruter) my network is a 500/500mbps. The wifi speed is low all over my house Cables from home central to ruter = cat6 1. If i use ethernet i ...
- Dec 08, 2020
Sollution that worked:
1. reset the Nighthawk RAX50 router with a needle ( pin ) on back where the LAN ports are
2. cut the power on the ISP modem/ruter
3. turn on the ISP modem/ruter again
4. turn on Nighthawk RAX50 again
5. run a full setup wizard again on Nighthawk RAX50
Then the speed got right,
testet on laptop and phone all over house
Wifi speed is now correct
Kind Regards
Cornelius
Nov 30, 2020Guru - Experienced User
What modem/gateway is it connected to?
What device are you testing with and what app are you using to test with?
You put you get full speed hardwired?
Did you ever try a factory reset and reinstall? Leave it default (other than ssid) during the install process and speedtest it once you get the basics setup.
