Ramiseesniblic
Sep 30, 2023Guide
Netgear Nighthawk RAX50 - Wifi 5ghz dropping internet connection. 2.4Ghz connection is fine.
Hello. My RAX50 has suddenly started dropping the internet connection on the 5Ghz Wifi. I have checked the configuration, changed the passwords and it doesn't help. The 2.4Ghz remains stable. ...
- Oct 02, 2023
I know you don't think you're using dfs channels, but there's a decent chance you are.
the RAX50 supports 160hz wide channels. so if you have the speed for the 5ghz set to "up to 4800mbps", its using dfs channels. Try setting your speed down to "up to 2400mbps" speeds. It still lets you use the full 4x4 antenna but narrows the 5ghz overlap to just 80hz and keeps you out of the DFS channels.
michaelkenward
Sep 30, 2023Guru - Experienced User
What actually happens? WiFi LED goes off? Client can't connect?
How is your WiFi configured?
By default these devices use a single SSID for 2.4 and 5 GHz.
- RamiseesniblicSep 30, 2023Guide
What happens is that any device connected to the 5Ghz network looses internet for a small period of time, then it comes back again. The 2.4Ghz WIFI is not effected. This is a real issue as it interrupts my work.
I purchased the router July 2022 and my technical support warranty has expired. It might be a hardware issue but I cannot raise a support ticket to get this confirmed.
- michaelkenwardSep 30, 2023Guru - Experienced User
2.4 GHz is slower than 5 GHz, but has a longer range. So runs a higher risk of getting lost.
Do the LEDs show anything?
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
