Ramiseesniblic
Sep 30, 2023Guide
Netgear Nighthawk RAX50 - Wifi 5ghz dropping internet connection. 2.4Ghz connection is fine.
Hello. My RAX50 has suddenly started dropping the internet connection on the 5Ghz Wifi. I have checked the configuration, changed the passwords and it doesn't help. The 2.4Ghz remains stable. ...
- Oct 02, 2023
I know you don't think you're using dfs channels, but there's a decent chance you are.
the RAX50 supports 160hz wide channels. so if you have the speed for the 5ghz set to "up to 4800mbps", its using dfs channels. Try setting your speed down to "up to 2400mbps" speeds. It still lets you use the full 4x4 antenna but narrows the 5ghz overlap to just 80hz and keeps you out of the DFS channels.
Oct 02, 2023Guru - Experienced User
What channels the 5ghz connected to?
Curious as if you're using a DFS channel you can get that when it switches off the dfs frequencies.
- RamiseesniblicOct 02, 2023Guide
I'm on Channel 36. Not using the DSF channels as there is an airport not too far away from me and I don't want to contest with any radar that they are broadcasting 🙂
In fact, I looked at the router (Virgin Media) logs and I was seeing alot of SYNC Disconnect issues which suggested an issue with the wider ISP network. I called them and indeed they are having issues. 24 / 48 hours they said..
- plemansOct 02, 2023Guru - Experienced User
