dcordell117
Sep 13, 2021Aspirant
NetGear NightHawk RAX50S
So I am having trouble setting up 2 Xbox’s on a nighthawk router. I ran 2 cat 6 to a switch that is running to the router. It shows I have a wired connection but I’m not getting connectivity. I am get...
Sep 14, 2021Guru - Experienced User
Connected by ethernet to a phone line module?
What is this phone line module?
Everything works at the router?
How is the router connected to the switch?
The wire that is connecting the router to the switch, does that work?
dcordell117
Sep 14, 2021Aspirant
It is actually a data hub that the switch is connected to that runs back to the router. Everything works except the Xbox’s
- plemansSep 14, 2021Guru - Experienced User
what data hub is it?
- dcordell117Sep 14, 2021Aspirant
Do one of the xbox's work directly connected to the data hub? without the switch?
You realize that that is a fast ethernet switch. Just a 10/100mbps switch and not gigabit.
