dcordell117
Sep 13, 2021Aspirant
NetGear NightHawk RAX50S
So I am having trouble setting up 2 Xbox’s on a nighthawk router. I ran 2 cat 6 to a switch that is running to the router. It shows I have a wired connection but I’m not getting connectivity. I am get...
dcordell117
Sep 14, 2021Aspirant
It is actually a data hub that the switch is connected to that runs back to the router. Everything works except the Xbox’s
Sep 14, 2021Guru - Experienced User
what data hub is it?
- dcordell117Sep 14, 2021Aspirant
- plemansSep 14, 2021Guru - Experienced User
Do one of the xbox's work directly connected to the data hub? without the switch?
You realize that that is a fast ethernet switch. Just a 10/100mbps switch and not gigabit.
- dcordell117Sep 14, 2021AspirantI got one of the Xbox’s to work(Xbox one S) but I could not get the other to work. It is an original, I’m not sure if that has something to do with it
