danielfr789
Jan 31, 2025Aspirant
Netgear Nighthawk RAX50V2 - Access Denied Bug SOLVED SOLUTION
I ran into the issue of not being able to log in to my router's GUI. I looked all over these forms for a solution, many saying just factory reset to resolve the issue. I then did some more sear...
- Jan 31, 2025
After updating fw, factory reset with the router DISCONNECTED from the ISP services. Setup and get to the home page, once there, then re-connect to the ISP service. Should be good there.
Ya. Passed this onto NG. No idea if or when they will do anything.
Jan 31, 2025Guru - Experienced User
Can do a factory reset and set up from scratch with the router OFFLINE from the ISP services and setup from scratch with v.28 FW loaded to keep the router up to date. Then connect to the ISP services. I saw this same issue on my v2. After the FR and setup from scratch, have not seen this issue again. https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/New-RAX41-42-43-50-54-V2-Firmware-Version-1-1-4-28-Released/m-p/2363771/highlight/true#M37956
danielfr789
Surely the new FW is usable, but the issue will persist. As soon as you connect it to the internet you will no longer be able to login to the router unless you disconnect it from the internet.
