danielfr789
Jan 31, 2025Aspirant
Netgear Nighthawk RAX50V2 - Access Denied Bug SOLVED SOLUTION
I ran into the issue of not being able to log in to my router's GUI. I looked all over these forms for a solution, many saying just factory reset to resolve the issue. I then did some more sear...
- Jan 31, 2025
After updating fw, factory reset with the router DISCONNECTED from the ISP services. Setup and get to the home page, once there, then re-connect to the ISP service. Should be good there.
Ya. Passed this onto NG. No idea if or when they will do anything.
danielfr789
Ah okay so what you're trying to say once you update to 1.1.4.28 that preforming a FR solves this issue. I had already tried that before even attempting to downgrade and it didnt work for me. Regardless we need a new firmware update ASAP
Jan 31, 2025Guru - Experienced User
