dlozier
Apr 23, 2025Aspirant
Netgear Nighthawk RAX70 has slow internet speed well below the maximum
I've been using this for a while with a 300MBs Spectrum connection. I just increased Spectrum to 500MBs and testing directly from modem to my PC gets me 600MB. I also have a gigabit router in which i...
- Apr 23, 2025
I found the problem and wanted to note this in case others see the same issue. It was in the QOS setting.
When I initially installed this on the Spectrum 300MB line, I ran the speedtest in the router and it used those numbers as the maximum, speed. it was set at 322MB. I had the router re-run this and we are now at 550MB down and 25MB up. Now the speedtest from my PC gives me the speeds I need.
dlozier
michaelkenward
Apr 24, 2025Guru - Experienced User
The general advice on QoS is that anyone with an Internet connection above 300 Mbps, some say 200 Mbps, should forget about QoS.
It was designed when people had slow Internet connections and wanted to slow down stuff so that they could game their lives away. These days speeds are so high that QoS is more a hindrance than a help. It just gets in the way of traffic, slowing things down.
Disclaimer: Just another user with time on their hands.
