00Maverick00's avatar
00Maverick00
NetGear NightHawk RAXE500 Need Help Please
So a couple hours ago my WiFi 6E the 6G channel has started going out and it's only the 6g when it disconnects it auto switches to the 5g and I don't know what has caused it. everything else connectio...
  • 00Maverick00's avatar
    00Maverick00
    Mar 19, 2023
    I think I got it fixed I did a few things to try and see if they worked. also I apologize I did have a update on my phone but that was at the beginning of this month. I forgot to mention it. but this issue only happened a few days ago. but i digress so far what I did was completely forget the network on my device and removed it from the router itself then reapplied the login into the network on "6G" and that has to to have worked. I wanted to thank everyone for there advice and input. have a good one.
