FuentesR's avatar
FuentesR
Initiate
Jul 20, 2023
Netgear nighthawk router R6700AX streaming issues
I have a Netgear nighthawk R6700AX.  Purchased within the last 2 years. Its actually in basement at one end of ~2000 sqft house.  Trying not to move it.  Good inbound speed of 400mb+ from Spectrum  ...
  • plemans's avatar
    Jul 20, 2023
    A couple things.
    1. 2.4ghz struggles with streaming because its sensitive to interference and isn't a very fast network
    2. the EX2700 is a base model n300 device. Its not suitable to streaming tv. extenders by their very nature (single/dual bands) cut throughput 50% of what their receive and with the ex2700 already pretty slow, its a poor choice
    3. Your home is only 2000sqft, if it made of wood/sheetrock and you don't have the router stuck in a utility room (the metal blocks wifi), you can centrally locate it and should be able to cover the whole home
    4. if not, I'd look at something like the EAX15/20. Put the primary router 1/3 in the way of the home and the eax in the other 1/3. (like this:  wall |------router----------EAX--------| wall
    the router and extender both broadcast omnidirection (basically in a globe) so you don't want them right next to a wall.
