FuentesR
Jul 20, 2023Initiate
Netgear nighthawk router R6700AX streaming issues
I have a Netgear nighthawk R6700AX. Purchased within the last 2 years. Its actually in basement at one end of ~2000 sqft house. Trying not to move it. Good inbound speed of 400mb+ from Spectrum ...
- Jul 20, 2023
A couple things.
1. 2.4ghz struggles with streaming because its sensitive to interference and isn't a very fast network
2. the EX2700 is a base model n300 device. Its not suitable to streaming tv. extenders by their very nature (single/dual bands) cut throughput 50% of what their receive and with the ex2700 already pretty slow, its a poor choice
3. Your home is only 2000sqft, if it made of wood/sheetrock and you don't have the router stuck in a utility room (the metal blocks wifi), you can centrally locate it and should be able to cover the whole home
4. if not, I'd look at something like the EAX15/20. Put the primary router 1/3 in the way of the home and the eax in the other 1/3. (like this: wall |------router----------EAX--------| wall
the router and extender both broadcast omnidirection (basically in a globe) so you don't want them right next to a wall.
Jul 20, 2023Guru - Experienced User
A couple things.
FuentesR
Jul 28, 2023Initiate
Thank You. Now have the EAX20 in office (middle of house) and seems to help. Was not a bad installation. WIll indeed look at how to best move the Router from corner basement to middle of house. WIll need to run cable from Modem to Router new location.
- plemansJul 28, 2023Guru - Experienced User
If you've already got the extender, you shouldn't really need to move the router. It'll do great with them properly spaced and give you great coverage.
