tz10uk
Apr 18, 2021Aspirant
NETGEAR Nighthawk Whole Home Mesh WiFi 6 System MK63 - Mesh through old walls
Hi have a Nighthawk R9000 plus 2 EX8000 configured as access points, as I have terable WIFI around my house, using this set up if I am connected to the R9000 I get cirva 300MB download, but if I am c...
Apr 19, 2021Guru - Experienced User
The r9000 with EX8000's will perform better than the MK63 system.
The MK63 system is only dual band. The EX8000's are triband and use a dedicated backhaul for the connection.
And if you've tried orbi, you've tried mesh.
The issue is the home's structure not supporting wireless backhaul.
You'd be better off to invest in a way to hardwire in your satellites/extenders.
Either using powerline (which can struggle in older wired homes), using moca adapters (ethernet over coax), or having your home wired with ethernet.
- tz10ukApr 20, 2021Aspirant
Thank you so much for your reply,
I have my AP running through powerLines and although my network is stable now the speed is inconsistent, did not consider old cabaling being the issue
Seems like cabling may be what will be required just did not want to do that in todays technical world :(
Thanks again for your reply
T
