rcnetgear
Oct 20, 2024Follower
NETGEAR Nighthawk WiFi 6 Router (R6700AX) AX1800
New Router set up. The ethernet LED is showing Red instead of Green. All devices connected to the ethernet are working normally, and so is the router. How do I fix this problem?
michaelkenward
Oct 21, 2024Guru - Experienced User
Red and green are speed indicators for LAN ports.
Read means that you have plugged in an Ethernet device running at 100 Mbps. It is green when the connection is 1000 Mbps.
Relax. All is well.
Just another user with time on their hands.
