david_2706
Jan 03, 2025Aspirant
netgear nighthawk wifi 6 router rax120
Hello, Friends: I just brought this unit and upgraded to the latest firmware. I'm trying to setup an PBX phone system I can't seems to do port forwarding to open HTTPS URL. Could someone please help...
david_2706
Jan 14, 2025Aspirant
Hi FURRYe38:
Thank you for reply, There was all configured on the PBX side, and it was worked fine with GrandStream router before I switched to Netgear nighthawk wifi 6. I don't understand even thought I enabled remote web management on and specify custom HTTPS protocol and port to device hosting IP address. but still got 403 Forbidden. I did contacted support but still haven't hear from them yet. I believes this is a poor design and it need to be fixed.
Jan 14, 2025Guru - Experienced User
IF you set up any port forwarding configurations on the router, be sure to disable uPnP on the router.
- david_2706Jan 15, 2025Aspirant
I did disable uPnP on the router. but it still didn't make any different.
Like i said this is a poor design and it's need to be fixed
- FURRYe38Jan 15, 2025Guru - Experienced User
Try enabling uPnP, disable the PF configuration, and put the PBX device into the DMZ on the RAX router and see.
Something you'll have to contact NG support about if this all fails for you.
enabled uPnP, disable the PF configuration, and put the PBX device into the DMZ on the RAX router still say 403 forbidden https://192.168.1.253 tried without http still same
I guess the NG support didn't have any answer for me. waited over 30 days now.
