MPalmeroni
Feb 12, 2020Tutor
NETGEAR Nighthawk X6S Smart Wifi Router (R8000P) - AC4000
Hi , My router is blocking some sites from day one nothing is blocked in security And today it’s blocked my company website so I can’t work or order. Any ideas how to sort this issue ? Thanks...
- Feb 12, 2020
The DM200 has integrated routing functions built in. If you didn't disable them on the DM200, it puts you in a double nat which can cause many different issues.
Try putting the DM200 in modem only/passthrough mode. Page 69 of the manual walks you through this. but here's the post from the manual.
1. Launch a web browser from a computer that is connected to the network.
2. Enter http://www.routerlogin.net.
3. Enter the modem user name and password.
4. Select ADVANCED > Advanced Setup > Device Mode.
5. From the Device Mode menu, select Modem (Modem only).
6. Click the Apply button.
The modem should then reboot.You can also try putting the R8000P in Access point mode if you prefer to leave the DM200 with its routing functions running.
But you can't do both. One needs to be in router mode.
Feb 12, 2020Guru - Experienced User
What modem are you using?
What firmware are you on?
have you tried changing dns providers? You could try google's at 8.8.8.8 or 8.8.4.4 or cloudfare at 1.1.1.1
You put that this has been going on since day 1. How long have you had the device?
MPalmeroni
Feb 12, 2020Tutor
Hi
I’m using NETGEAR DM200-100EUs. The nighthawk Router is on latest firmware. Not sure re the modem.
I have not tried changing DNS , but will do. Should I be changing any setting on modem
As I have only be logging into router
Thanks
Thanks
- plemansFeb 12, 2020Guru - Experienced User
- MPalmeroniFeb 12, 2020TutorPlemans thanks so much it worked 😋
Happy out you don’t know how much time I spent reading forms check I things
Would you still advise change DNS to Google’s- plemansFeb 12, 2020Guru - Experienced User
No,
If its up and working, it was the double nat issue.
Glad to hear you got it working correctly though :)
- plemansFeb 12, 2020Guru - Experienced Userhere's the support site with manual
https://www.netgear.com/support/product/DM200
