MPalmeroni's avatar
Feb 12, 2020
NETGEAR Nighthawk X6S Smart Wifi Router (R8000P) - AC4000
Hi , My router is blocking some sites from day one nothing is blocked in security And today it’s blocked my company website so I can’t work or order. Any ideas how to sort this issue ? Thanks...
  • plemans's avatar
    Feb 12, 2020
    The DM200 has integrated routing functions built in. If you didn't disable them on the DM200, it puts you in a double nat which can cause many different issues.
    Try putting the DM200 in modem only/passthrough mode. Page 69 of the manual walks you through this. but here's the post from the manual.
    1. Launch a web browser from a computer that is connected to the network.
    2. Enter http://www.routerlogin.net.
    3. Enter the modem user name and password.
    4. Select ADVANCED > Advanced Setup > Device Mode.
    5. From the Device Mode menu, select Modem (Modem only).
    6. Click the Apply button.
    The modem should then reboot.
    You can also try putting the R8000P in Access point mode if you prefer to leave the DM200 with its routing functions running.
    But you can't do both. One needs to be in router mode.
