rjohns75
Feb 15, 2023Aspirant
Netgear Nighthhawk and Blink Camera local storage issue
I was having trouble getting the Blink Camera local storage feature to work on my Nighthawk network. All of the Blink features worked except for the ability to locally store recorded video clips to t...
- Mar 19, 2024
I only thought to update this when I noticed the sync module device type was set to camera after I started troubleshooting. Hope this works for others.
rjohns75
Nighthawk RAX45
Let me start by saying I'm only posting this to help others that may have this problem in the future. I just don't understand why it worked.
Yes I read all of those posts but they are not related. I searched for at least a month and no one had the same issue. I spent atleast 6 hours on the phone with Blink tech support and they couldn't find a solution. Just by chance I decided to create a guest network because another user described how selecting "allow guests to see each other and access my local network" solved his problem with his guest network and Blink cameras. I initially dismissed this approach because I was using my main network and not a guest network for my cameras. Even when I did create the guest network (which got everything working correctly), I didn't need to select the option described above.
Regarding the Blink setup, it is similar to how you described Arlo. The Blink Sync Module accepts a USB drive . The camera is wirelessly connected to the Sync Module and the wifi network. As I previously mentioned, everything worked, including live view but it wouldn't store the clips to the USB on the Sync Module.
I'm simply trying to understand if there is a difference between the primary and guest networks that resulted in all of the camera functions working on the guest network and not the primary network.
Robert
