rjohns75
Feb 15, 2023Aspirant
Netgear Nighthhawk and Blink Camera local storage issue
I was having trouble getting the Blink Camera local storage feature to work on my Nighthawk network. All of the Blink features worked except for the ability to locally store recorded video clips to t...
- Mar 19, 2024
I only thought to update this when I noticed the sync module device type was set to camera after I started troubleshooting. Hope this works for others.
michaelkenward
Feb 15, 2023Guru - Experienced User
rjohns75 wrote:
I'm simply trying to understand if there is a difference between the primary and guest networks that resulted in all of the camera functions working on the guest network and not the primary network.
Guest networks don't operate in the same way as the rest. But you found that out already.
They don't work to the same "rules".
The question is, how do they differ?
Did your search for guidance include this?
Search - NETGEAR Communities – guest network isolation
rjohns75
Feb 16, 2023Aspirant
I just read through some of those and those user seem to have the opposite problem (that want to isolate guest devices from each other and the primary network). I'm going to assume the following theory without the ability to confirm it.
- To many devices on my primary network prevented the camera and sync module from sending certain data (eventhough the network bandwidth was not congested)
- Putting the camera and sync module on a guest network that is only used by those devices meant that the only communications on this network would be between the devices that need to communicate with each other.
Not sure if this is correct but hope it helps someone in the future.
Robert
- Verity7Aug 01, 2023AspirantHi All,
Just wanted to share my experience... it turns out my secondary router being set as wireless access point was preventing Blink sync mod from connecting. Kept getting error about network password, blah,blah,blah... I knew that was false.
Since my Blink was not connected to that router, I hadn't really thought if that configuration as being the culprit. After being unsuccessful with just about every suggestion here, I started backtracking steps. Once I reverted to standard router setting (not an access point), I was able to reconnect Blink sync mod.
I hope it helps someone!
Verity7- michaelkenwardAug 01, 2023Guru - Experienced User
Nice detective work Sherlock.
A couple of questions:
- was the AP mode device running with a different SSID/password from the main router?
- when (if) you put the thing back to AP, did the Blink stay connected?
